Model complex tube with bends
Unusual scenario, but I have been asked to model a railway track (what we do for our clients!).
This means I have to model a 3d tube that bends all over the place. See image below.
Any suggestions on where to start?
3 REPLIES 3
If you are handy with GDL it would be quite simple for the TUBE command.
Or the Morph tool will be your best bet.
I would probably make just a 3D morph line (curve) for the path and then extrude a circular profile along it.
Or have at look at this website and you might find an object you could use.
http://archilib.od.pagesperso-orange.fr/
Thanks Barry.
Ended up using a series of elbows which were then placed in a combination of sections and plans (as you cannot rotate these in 3D - which made for some fun language).
Close enough I think
Erich
You could have turned the "series of elbows" into a morph which would rotate in 3D. I just did this to make a light fixture for a client.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
