Module - Sections and Autorebuild.
I am creating a project with many small houses, so i decided to create each one in a seperate module. I created the plans, and then sections and elevations. I then make sections pure drawing to edid them as i please.
Save the project exit. When i open the project again, it rebuild the sections and elevations and i loose all my work.
I also create some view sets, but these are gone too. The initial ones are restored.
Does anyone know how i can stop the elevations from rebuilding?? and the view sets from reappearing?
I just found the answer.
Modules dont hold that information. No sections no elevations
TomWaltz
You can use PLN files as hotlinks as well. Modules are nice, but you cannot really "document" then inside the .MOD file.
Tom Waltz
You can also merge the files together using the File>Merge and then they will be in the same drawing yet still there own drawing. then all will stay intact.
