‎2007-07-26 12:08 PM
‎2007-07-26 05:07 PM
PatriciaLeão wrote:A MOD file is basically a dumbed-down-version of a PLN: for instance, it only contains the attributes that are being used, and doesn't bring along with it a bunch of extra-non-needed-stuff. Also, MOD files are
can anyone explain me what's the difference on inserting a .mod or a .pln file as a module?
‎2007-07-26 05:51 PM
‎2007-07-26 06:13 PM
PatriciaLeão wrote:No -- you want to use the MOD because of its smaller size -- this is the purpose of a MOD (to act as a hotlinked file)!
Thanks a lot Laura. So there's no use on inserting a .mod...? It may be a smaller individual file, but after inserted, mod or pln, result the same final file size. Is this??
‎2007-07-26 07:29 PM
‎2007-07-27 11:08 AM
Link wrote:
But it is not difficult to replace the modules, really. Just delete the existing ones and place the new multi-story module in one go.
TomWaltz wrote:
If you use the publisher, you can control mass creation of modules using a stripped down layer set.
