Modules in a teamwork project?
I can't find out how to open a module saved in the teamwork library!? I suspect I should keep the module file (.mod or .pln) outside the teamwork library but wanted to check so that I'm correct about this.
Thx Mats
3 Replies 3
Mats_Knutsson
Mentor
Also...any hassles with copying hotlinks instead of placing them? Placeing is tedious if you have 100 hotlinks...
AC 25 SWE Full
Link
Hi Mats
The answers are yes they must reside off the BIM Server (assuming you're talking about individual mod files) and no, there is not a problem with copying HLMs instead of placing them. It's the same thing, just make sure grouping is enabled.
You may be interested in this thread as I explain the process in detail, including two screencasts.
Link.
Mats_Knutsson
Mentor
Link wrote:
Hi Mats
Link.
Brilliant!
Thanks Link!
AC 25 SWE Full
