Morph Problem
clints
Archicad 24 on an Imac 2020 but I've had this problem occasionally in the past as well. I made a morph, then attempted to "tip it up" 90˚. I did something where after I select to rotate, when I attempt the click on the face (with the protractor) to rotate it around that face it will only select the face that is directly beyond the face I am pointing at. How do I undo this? It makes working with morphs almost impossible.
Clint
ArchiCad 27 | Mac Studio 2023 w/ 27" mac monitor | M2 Ultra | 64 GB | Sonoma 14.2.1 | Indiana
Hello Clints,
Did you use the white arrow ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
This may help fix the problem.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=70309&p=313934&hilit=behind#p315694
