2022-02-04 08:18 AM
I need to create a spiral line to show in 3D the effect.
It should be seen like as spiral in plan and in elevation.
I tried with that Spiral beam, and curved ramp as shown in the Forum.
But in this, in plan it is showing as a circle, and in elevation it is on one side, in section it is proper spiral as want.
I have attached the images.
And I have drawn the spiral in plan with morph, as attached image(screenshot 288,289), how to extude(for extrude I know we need a thickness) I dont want like that,
or make look spiral same as the plan in 3D.
It should be look like the image(screenshot 290)
2022-02-04 09:02 AM - edited 2022-02-04 09:03 AM
Try this - its one of my GDLS and You can use a self drawn profile-manager-profile within it.
https://bimcomponents.com/GSM/Details/23828
AC-Edu-File Aut version with example
2022-02-04 09:35 AM
A newer version - the german forum to download the latest: https://forum.graphisoft.de/viewtopic.php?f=6&t=26945&hilit=Rampe+harmonisch
And the latest Vid:
2022-02-08 08:27 AM
2022-02-08 01:59 PM - edited 2022-02-08 02:28 PM
Did you try to drag my object into Archicad direct from the bimcomponents-link.?
In the GDL-Dialog, you can give it much more points - so it will look much smoother! and - Its possible to "give in" much more than 360° into the dialoge to do this in just one "thing". This cant be made with the mouse - just in the dialog.
2022-02-09 01:02 PM
No, it is not importing,
I have AC 19, but the object is in AC 23.
So Yesterday I dint imported, now tried to import, but it is not importing
2022-02-09 04:15 PM
AC 19 can not open/import AC 23 objects.
