Domagoj Lukinic
Move multiple labels at once
Hi all!
I have an assailment to label all load bearing elements for civil engineers.
I am having some difficulty's aligning the labels right.
What do I want:
To select multiple labels ( Like ctrl+F ) but to select them in a way that label arrow is in a fixed position and only the bubble moves...
I want this:
If you go ctrl+F I am getting this result:
I don't want this
Is there a way to select labels without manually clicking on each every one of them to get that label "selection"? If not is there a add on or something that provides this feature?
Thank you in advance!
Have a great day!
1 Reply 1
Miha_M
Check the video tutorial for aligning, distributing and adjusting labels in Archicad. Maybe this can help you solve your problem. Labels (graphisoft.com)
| Archicad 4.5 - 29
