Move multiple slab nodes at the same time
Hello.
I have one problem. I'm designing a skyscraper with 45 floors. Each is a little bit different from the ground to the roof an it is not rectangular.
I have to copy a slab from the previous floor to the next and then reshape it by moving nodes - 16 nodes a floor. Is there a way to select multiple nodes and drag them at the same time. I have 4 "groups" of nodes that should move in the same direction and that would really save me some time.
Thanks for any advice.
Erwin Edel
Use the marquee tool. Thin outline = one story, bold outline = all stories.
You can stretch what is in the marquee area. Hotkey ctrl/cmd + H.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks a lot! You saved me a lot of time
