SOLVED!
Move objects from layer before deleting it
A_ Smith
In previous version of AC (i think AC26 and earlier) if you deleted a layer there was a warning window "move objects to another layer?" Not just delete it with all objects it has...
Could someone please explain why AC doesn't give such opportunity now? Mabe there another work around?
AC 22, 24 | Win 10
1 ACCEPTED SOLUTION
Solution
insideru
The option is still there. You just need to have objects on that layer. If this doesn't pop up, then there are no elements on that layer.
ARCHICAD 28 INT
macOS Sequoia
2 REPLIES 2
Solution
insideru
ARCHICAD 28 INT
macOS Sequoia
A_ Smith
My bad. You're correct.
AC 22, 24 | Win 10
