Multi-Elevation marker not working in AC 10
Hi folks,
The multi-elevation marker is not working on one machine in my office, you know the one that puts the drawing # at the point, and the sheet # in the middle.
I've checked the loaded add-ons. Interior Wizard, yes, Interior Elevation yes.
It doesn't matter if its new project or existing, it won't show up. Something about an error at line 12 of the 2d script.
Could there be something about the settings on the machine that keep it from generating properly?
Thanks.
-Nathan in New York
2 Replies 2
Scott Bulmer
Nathan,
Using the same workstation, it works with one project and not with another. I've tried everything and have no explanation. Its pretty frustrating because the settings are the same in each circumstance.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
We un-installed archicad, and then re-installed it. For wahtever reason, the marker now works.
-Nathan
