Multi-Plane Roof Doesn't Work
I simply can't get the Multi-Plane roof tool to respond to creating a broken pitch roof with a 3.5 in 12 lower section and a 6.5:12 upper- it won't change the roof at all.
3 REPLIES 3
David Maudlin
richardaia:
In the Roofs Settings > Multi-Plane Geometry > Roof Levels, is the lower level roof Elevation set to a low enough height?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks on all counts David. That light bulb went off in my brain at 1 in the morning. You can feel really dumb when the solution turns out to be something you should have seen right away.
Richard
David Maudlin
Richard:
It looks like the default value is the Imperial equivalent of 2 meters, a high value if creating a small residential scale roof, so not hard to miss.
David
