Multiple Wall Type details not showing correctly
Really trying to step up my a Game and get better at using ArchiCAD so began a 25 building control package with the intention of doing an amazing 3d model however it seems harder than first thought !
Im having an issue where two wall types intersect vertically
I have a substructure wall (dolly block with external render) which sits on the same level as my beam and lock floor with another composite beginning directly onto of it and continuing the height of the building.
As the Composites both contain a cavity (I used Air as the material for this) I was hoping they would intersect and not cause and problems however when I try and create a 3D section the bottom of the cavity shows up in the detail and also in the 3d mode when I cut through the building.
I hope that makes sense but if not I have attached a photo of both instances.
0 Replies 0
