2008-06-24
08:06 PM
2023-05-23
05:00 PM
Rubia Torres
2008-06-24 08:46 PM
2008-06-25 02:17 PM
2008-06-25 03:21 PM
xristina wrote:You can't distribute along a path with multiply command. But as Dennis said, there is an align and distribute tool in AC12.
can you not use edit/ multiply and use one of the options in there?
btw, it would help if you changed to signature to show your AC version and computer spec.
2008-06-25 03:54 PM
TurboGlider wrote:While this is true, nothing stops you from multiplying in the 3D window, assigning the Z difference as required, and then distribute in the plan ...xristina wrote:You can't distribute along a path with multiply command. But as Dennis said, there is an align and distribute tool in AC12.
I think, and almost sure, it will work only in '2d' there you can't change Z-coordinate because we don't have 3d polylines in ArchiCad.
2008-06-25 06:12 PM
Djordje wrote:Take a look at OBJECTiVE - it has tools to align and distribute in both 2D and 3D:TurboGlider wrote:While this is true, nothing stops you from multiplying in the 3D window, assigning the Z difference as required, and then distribute in the plan ...
