My Shortcuts stops working
Hi all,
Every now and then my keyboard shortcuts stops from working, and I don't know if it is a bug or am I pressing a key without noticing.
Has anyone encountered a problem like this and has a solution?
thanks in advance
you may have to just re-apply your shortcut scheme in your work environment.
And maybe you can look to make sure there there are still shortcuts applied to your commends in the work environment.
I say allways check the obvious first, I find that the obvious solution is usually the solution.
Found the problem -
When I pressed Alt+Shift as a part of a shortcut, it switched the language in my computer and because of that the shortcuts have stopped from working
