Navigator disappears when working with two monitors
I hope someone can either provide a temporary work-around or tell me how to fix this problem. I have a MacBook that I hook up to two monitors some of the time. When I drag my navigator into the secondary screen and forget to drag it back before shutting down, I cannot seem to get the navigator back on my main screen. When I don't have access to the second monitor is there any way to get my navigator to show up again? I really need it to view my second floor!
Thanks!
3 Replies 3
Try selecting one of the standard work environments.
This is good for the quick fix, but for the long run you may want to set up two work environments. One for the two monitors and the other for the MacBook by itself.
Thanks guys, mystery solved! The first option did work and I will definitely be setting up some environments.
