2010-06-3008:19 PM - last edited on 2023-05-3002:14 PM by Rubia Torres
2010-06-3008:19 PM
I am new to ArchiCAD and I am using the MEP routing tools and I want to connect a flex duct from the diffuser to the duct. I have an 8" diameter branch line and I have placed a diffuser. when I go to connect the flex duct to the round duct it tells me that it won't work because they are different connections. When I create a take-off fromt he round duct and then connect the flex duct it works, so i am assuming that i need to find some sort of connection for the end of the duct to connect the felx duct to. Could someone give me some advice?
The Connection Type of the Flexible Duct is Simple Body, while that of the Duct Straight (the target) is Flanged.
You should change the Connection Type of the Flexible Duct to Flanged.
So their Connection Type should be the same.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
