‎2005-04-11
08:05 PM
‎2023-05-23
03:36 PM
Rubia Torres
‎2005-04-12 02:19 PM
manuni wrote:manu:
2. For an interior layout presentation i want a sectional axometric view of the total interior. I am attaching a sample file. This is exactly what I want. But I couldn't figure out how to do so in archicad. All the sectional planes created in archicad is in the plan only. I tried to give the effect by reducing the height of the walls. But the doors and windows will project out.
‎2005-04-14 10:44 PM
‎2005-04-19 08:58 PM
‎2005-04-20 04:01 AM
‎2005-04-20 04:19 AM
‎2005-04-20 09:18 AM
LiHigh wrote:Dear LiHigh,
Is this what you are after?
It was done using Roof tool with Polyroof geometry Method. initially, you'll get a elliptical base roof with identical pitched angle for all segments. So, you need to manually edit the individual segment's nodes and angles so that all the roof segment would meet at the center peak.
‎2005-04-22 11:13 AM
‎2005-04-22 01:38 PM
So, is this waht you want?[/quote wrote:
Dear Kliment,
That is exactly what i want. Could you please explain it in a step by step procedure so that i can also do the same...As i mentioned earlier I am not so proficient with AC.
...thanx®ards
...manu
‎2005-04-22 02:21 PM
