2005-01-22 04:16 AM
2005-02-11 06:34 PM
2005-02-11 10:15 PM
Rick wrote:I completely understand why you "completely avoid" it. I've been doing "optioned" plans for a number of years as well and have never devised an efficient method of layer management or reference files to achieve the options...its just not realistically possible with plain ol' ArchiCAD...This is where Options Manager fills a definite useability void.
...When I first started transferring my plans to the computer (AC 4.5) I was combining multiple options into a base plan. With Quickviews and the Publisher that potential is enhanced. However I now completely avoid this for many reasons......and the more complicated you build the option capacities, the greater the potential for human errors.
Rick wrote:The reason you should bother is that options tend to have many dependencies that are difficult to control in one file or multiple copies of the files. A simple extended family room could modify the foundation plan, framing plan, electrical plan, roof plan etc.,etc.,etc...What happens when you need to adjust a design based on a problem you find in the field? Are you satisfied with having to coordinate that simple change in multiple copies of the plan?
Sure, you can Quickview the differences (as an example) the floor 1 plan having stairs to the basement, different elec plan, and a different building section etc... than the crawl foundation version, but why bother when it is cleaner to copy the file, make the changes and keep it clean.
Rick wrote:Its not a loss if your satisfied with the status quo in your current operations...but, what if your customers could select options via a simple form on your website that generated a text file. And then, what if you open your fully "optioned" plan, import this text file and it toggles on and off their specific requests. Now save the plan, update your pre-linked Layout book...print the PDF..and your done! This is a "customer specific" or, in Volume Builder terminology, a "site specific" version of the plan. If you only offer limited options this might not see all that impressive...but if you offer the plethora of options typical US builders do these days it is!
So, I'm sad the Mac is left out, but it does not seem like any big loss to me. I sell plans every day. I sell CAD files regularly. I have been doing this since the early 90's. I have yet to have a customer say they are on Archicad, so I doubt this new feature is a big loss for my business.
Rick wrote:Surely you're not serious. OK, so "Joe builer" who runs his business out of the back of his pick-up truck might not ...but, I can assure you medium to large Volume Builders will stand up and take notice. The builder market represents a very lucrative and currently untapped opportunity for Graphisoft...what's good for graphisoft will be good for all ArchiCAD users.
My feelings are more along the lines of GS should stop trying to win over the spec builder. They want use AC in any large numbers anyway. That's why God made Chief Architect.
2005-02-11 11:53 PM
2005-02-12 12:55 AM
Steve wrote:Steve,
Key notes- big deal, i have a better way of managing notes already.
2005-02-12 02:08 AM
2005-02-12 05:50 PM
Also, in your multiple file technique, you open the door for the possibility of too many errors/variances. The more volume your company does the more inefficient it will be.... A simple extended family room could modify the foundation plan, framing plan, electrical plan, roof plan etc.,etc.,etc...What happens when you need to adjust a design based on a problem you find in the field? Are you satisfied with having to coordinate that simple change in multiple copies of the plan?That's not really what I am referring to, sorry if it was not clear. There are several issues. This is why I find it best not to make the model try to do more than produce one design. If someone wants plan XXXXA, but wants to extend the family room, then I copy the plan file and make the changes. If a field adjustment comes up, I open the plan under their file name and adjust it, so there is no need to "coordinate that simple change in multiple copies of the plan". I have many floor plans that have different "looks". This is where I think GS is trying to help the residential users. I started out trying to have all variations in a single file. This is where you can get into trouble and it is so much cleaner to copy the file, change the porch, roof, and few windows.. whatever, and be done with it. If you keep variations in one file you can very easily loose track of you database for material take offs, plus you end up spending more time making sure you have the right options on the right quickview etc. I just don't think an option manager would help my work, and since I deal with hundreds (thousands) of builders and know the market demands, I feel qualified to say if GS wants to package AC for residential users then they need to spend time making it simple, not more complex. If a builder, or residential designer watches a presentation at the National Home Builders Show and sees templates that would allow them to quickly build a model and generate a material list, then they would have something. Chief Architect does a much better job of this. But, Chief Architect is like flying a piper cub and AC a high-tech jet.
but, what if your customers could select options via a simple form on your website that generated a text file. And then, what if you open your fully "optioned" plan, import this text file and it toggles on and off their specific requests.It's a nice thought, but not realistic for my work. If I take one of my plans (as an example) and open up say 10 files of that plan being modified, there would be very little in common with the changes. It's not like ordering a car. Sure, you could spend hours developing such options to turn on and off, but the return on the investment would be frustrating. If you are a high volume contractor and you have a list of priced out options, then it makes sense, but that's a small percent of the industry and can already be handled easily. Marketing plans is different than marketing homes.
2005-02-12 08:08 PM
2005-02-12 09:25 PM
2005-02-12 11:26 PM
Rick wrote:
Dan... yes, my Chief Architect was intended humor... but not without some truth, in my opinion.
IMHO a well thought out templet system linked to a well developed database would be a better marketing package for GS to target the residential builder/designer. But first they need evolve the calculate functions into something much much better.
2005-02-13 12:44 AM
Hello
Interesting post,Project Building is much like a sausage factory,the ingredients go into one end and the product comes out the other?
They dont need complex processes and jet pilots but they do need a good lab for analysis and people to crank the handles.Its a very interesting business and your right huge profits for those that get the processes and recipe right.
Good Luck
