No snap points when trying to split
Steve Jepson
Anyone else see this? I find my self unable to find nodes when I think there should be one. One situation is in 3d when I try to split something. It does split at the node if you happen to be on it with the cursor but it does not display the node points so you can see where you want to split it.
In a 3d view, try to split a wall or something at the center or special snap point. I can't see them. They are visible if I can select the wall but don't show up when I am trying to split it.
4 REPLIES 4
Seems intermittent.
I selected a wall to split but couldn't activate the special snaps after I selected the split tool - I could only activate them before I activated the split tool.
So I split the wall at a random point.
Then the remaining portions worked fine and I could activate special snaps after the split tool was active.
I undid back to the original wall and still had the same problem.
Drew a new wall in 3D, selected it, activated the split tool and the special snaps worked on that wall, but not the first wall.
I panned in 3D and then the first wall started working as expected.
Drew a new wall in plan and viewed it in 3D.
Same problem as the first wall - no special snaps after activating the split tool.
I panned to the side a bit and then they started working.
So panning slightly seems to be the trigger to make it work.
It's annoying that we have to do that.
Steve Jepson
another example of missing nodes would be this.
There are times when I need to use that node and it's missing.
I should say, not being displayed. Perhaps there is some reason?
I've been getting some odd node detection and smart cursor behavior in 3D. The check mark flickers a lot and I really don't like to click if I haven't got a steady lock on the point or edge. It also seems that the 3D grid blocks detection of some nodes. For example I'll lose center points when the grid is in the way but can get them back when I orbit around or change the grid.
Erich
I've seen some of the same behaviour and am also getting difficulty getting objects to select without orbiting around to a different view point in 3D.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
