SOLVED!
Non-vertical balusters on railings
rakurs
Hello, everyone!
I would like to know if there is a relatively easy way to create railing like this one:
I have not scratched the surface of GDL and I'm a bit hesitant to do so because of time constraints, but I'm open to suggestions.
As I see it, I would need to create a custom panel with one "V" and then multiply it along the rail with set panel width. Of course, I may be wrong.
Thank you all in advance!
Operating system used: Windows W10Pro 22H2
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
1 ACCEPTED SOLUTION
Solution
Look at modelling and saving the 'V' as a custom baluster.
2 REPLIES 2
Solution
Of course, it is not very (easily) configurable, but it will work for this project phase. Thank you!
Setup info provided by author
