Not able to expand the calculate menu
I went to options preference and iam not able to find imaging and calculation option.even i went to workenvironment and check out the menu option,where iam not able to find the imaging and calculation option.please help out
regards
ashok
Go to Options/Work Environment. You probably have the menu structure set to Basic. Change to a different scheme and click the Apply button. I see that you are in India so your dialogue box may look a little different but This is where you need to look.
Woody
Ben Odonnell
If you are not using the US version it will look the the attached image.
You will need to apply the expert mode.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
If you want to keep your profile, just add the commands to the respective menus.
-Open Work Environment
-In the tree structure find Command Layout schemes/Menus
-In the 'customize Menus' tab on the right set up the columns like this:
- on the right select: Build this menu: Calculate
- On the left select: 'all commands by theme'
- then copy the required commands from the left column into the right column.
- Don't forget to save it as a scheme
Gergely Kmethy
