KimM
Not saving plan
Hi, I am very new to Archicad 25.
I have recently saved my decking plan but when I go out of it into another plan it has disappeared?
I have saved it onto a USB and my computer and can see the deck when I first open it but as soon as I go out of the folder it’s gone?
any ideas what I’ve done wrong?
thanks!
4 Replies 4
Miha_M
Check some Archicad basics, as the view display can be controlled through various settings (layers, layer combination, renovation filters and other graphic override settings).
Take a look at this video from Eric. It's based on an older Archicad version, but the basics are still the same.
| Archicad 4.5 - 29
Noemi Balogh
Check out Archicad basics here too: https://community.graphisoft.com/t5/Let-s-get-started/tkb-p/tkb_configure/label-name/archicad%20basi...
I suspect you might publish to a temporary place, but if you could elaborate on your problem more, the Community might be able to help you better.
Noémi Balogh
Staff Community Expert, Admin
KimM
Thanks Miha, this is very helpful.
KimM
Thank you Noemi
