2022-05-30 10:29 AM
Hi, I am very new to Archicad 25.
I have recently saved my decking plan but when I go out of it into another plan it has disappeared?
I have saved it onto a USB and my computer and can see the deck when I first open it but as soon as I go out of the folder it’s gone?
any ideas what I’ve done wrong?
thanks!
2022-05-30 12:51 PM
Check some Archicad basics, as the view display can be controlled through various settings (layers, layer combination, renovation filters and other graphic override settings).
Take a look at this video from Eric. It's based on an older Archicad version, but the basics are still the same.
| Archicad 4.5 - 29
2022-05-30 01:36 PM
Check out Archicad basics here too: https://community.graphisoft.com/t5/Let-s-get-started/tkb-p/tkb_configure/label-name/archicad%20basi...
I suspect you might publish to a temporary place, but if you could elaborate on your problem more, the Community might be able to help you better.
Noémi Balogh
Senior Community Expert, Admin
2022-06-05 08:01 AM
Thanks Miha, this is very helpful.
2022-06-05 08:02 AM
Thank you Noemi
