Object overshadowing the cut line of a wall
Hello to everyone,
First time posting, new to the forum, a basic question:
How do i correct things so the wall cut line is not being overshadowed by the object line in the attached picture?
Thank you,
David Maudlin
saleas21:
Use the Display Order commands Bring Forward and Send Backwards on the elements to get the Wall over the Object.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
saleas21:
Thank you very much for your answer
