Objects aren't hatched in section :(
Heyya.. Can someone help me ? I have a house which is imported from 3ds max through a .3ds format... Anything works fine but I would like to have the cutted walls with a hatch(fill), how it's normal Can it be done?
3 Replies 3
Have you check your model view setting?
David Maudlin
mlegs:
I think these types of objects do not convert as solid bodies, just planes, so there is no hatch.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
Correct. It is only the surface mesh.
You can open the 3D script and try adding MODEL SOLID statement.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
