‎2009-09-17
10:05 AM
‎2023-05-23
04:53 PM
Rubia Torres
‎2009-09-17 10:56 AM
‎2009-09-17 12:03 PM
‎2009-09-17 01:39 PM
ess24 wrote:It also allows you to open the dialog box for the element to see its attributes, but the "OK" button is grayed out, so the attributes cannot be changed.
Can anyone explain to me the benefit of being able to 'select' an object on a locked layer ?
‎2009-09-18 12:37 AM
‎2009-09-21 01:52 PM
David wrote:You can also find out how many instances of a certain element you have, regardless of whether they are locked or not.ess24 wrote:It also allows you to open the dialog box for the element to see its attributes, but the "OK" button is grayed out, so the attributes cannot be changed.
David
‎2009-09-29 02:36 PM
