2014-08-19
06:15 PM
2023-05-24
08:57 AM
Rubia Torres
2014-08-20 04:17 AM
2014-08-20 04:35 AM
2014-08-20 04:58 AM
2014-08-20 01:44 PM
2014-08-20 03:48 PM
Wall‐Wall IntersectionsBut I am not sure I would have realized this was the issue either.
• Requires Reference Line intersection
For Wall‐Wall junctions, it is not enough that they collide: their reference lines must also intersect. The element (or skin) with the higher‐priority Building Material will cut the one of a lower priority.
• Junction Order for Equal‐Priority Walls
If two Walls of the same priority meet (their reference lines intersect), use Junction Order to control the element level junction.
2014-08-20 03:58 PM
2014-08-21 02:30 PM
Erich wrote:Try changing the upper walls to a higher Junction Priority, or the lower walls to a lower Junction Priority.
It is also odd that changing the junction priority of the lower concrete walls did nothing but changing that of the upper composite walls changed the intersection.
