Offseting Tips
can someone drum up a simple offest command...you would think there would be one....for example if a create a joined polyline and fillet the edges....why can't I do a simple copy offset.....just curious
12 Replies 12
There is also the new pet palette icon for offsetting concentric arcs. I've just been working on some parking and sidewalks and it comes in very handy.
Have a look at the previous lively discussion on this hot topic (last entry: 11th Feb) There were 43 replies and 2681 views! (Sorry I don't know how to insert a link.)
It's the 5 steps that get me. Personally I always use Autocad for site layouts. If you set up your road centre lines as polylines, a single click gets you all the kerb lines, and one more click all the footpaths.
TomWaltz wrote:
The technique is a little sideways, but REALLY powerful once you get the hang of combining offset and magic wand.
For example:
  • Soffit/overhangs around a building
    Footings/foundations offset from each side of foundation walls
    Bulkheads around a room perimeter
Excellent tip.
But I am sometimes annoyed by the fact that offset w/ magic wand picks up all the connected elements. I would like control over this behavior; the ability to magic-wand a line by itself. Maybe the offset-all functionality could depend on the originals being grouped.
This behavior of offset means I've never really developed the habit; I usually drag a copy instead. (Starting AC in the pre-offset days is part of it.) For polygons, copy then resize. For arcs, copy and resize w/ the palette button, often manually editing the radius in the R field.
Also, you can't use offset to cut a hole in a selected polygon.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
