One end of roof higher than the other end
Hi!
I wonder how I can make one point of the roof ridge higher than the other end. Is this possible for normal gabled roof? Everything I try has failed, so I am hoping you have a good answer ))
DGSketcher
Legend
Yes, Archicad can do this. What you need to establish is the angle of the roof base line in relation to the ridge. For one end of the ridge to be higher than the other the base line has to be further away at the higher end. You can't have one gable of the roof at 30 degree and the other at 45 degrees as this would be trying to twist what needs to be a flat plane. If you have 3 points e.g. both ends of the ridge and a point at the eaves visible in 3D, you can set up the required roof plane in the 3D window and Archicad will create the required base line for the points.
Here's a couple of links to help you...
https://helpcenter.graphisoft.com/user-guide/76469/
https://helpcenter.graphisoft.com/user-guide/76472/
Thanks! That helped!
DGSketcher
Legend
You are welcome, I am glad you have it working. There's a lot of help available on this forum if you ask the right questions in the right way.
