IFelix-11
Open Web Joists and Interior Elevations
Hey all, just wondering how to get some beams to show up in certain elevations. Keep in mind, all interior elevation layer settings and properties are identical. The joist is placed right under the mechanical units, as shown in the view running parallel with the joist.  I've gotten the views that run parallel with the joists to show up, just not the ones that are perpendicular to them. Let me know if you guys have any ideas,
Thanks
2 Replies 2
Marc H
Hi IFelix-11,
Did you check your horizontal setting? May want to check both IEs have infinite horizontal range, which includes more model elements.
You can also increase the vertical range of the IE if you want to include the mechanical units on the roof for reference.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
IFelix-11
Marc,
Both of the ranges (vertical and horizontal) are set to infinite. Quite a tricky little bugger!
