Open an old archicad 7 file
Hi!
I try to open with Archicad 9 a PLA file made with 7 and I have this message:
" Input file is incorrect or memory full "
Please any Help?
Thanks
4 REPLIES 4
David Maudlin
Giuseppe:
You can try "Extract elements to a folder" rather than "Read elements directly from archive" when opening the .pla file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David for your hint, I will try monday @the office.
David Maudlin
Giuseppe:
Recently I brought a project from AC 6.5 to 17. I ran into your error message at some point, and I think changing from archive to folder solved it. Selecting the folder rather than the archive option definitely resulted in fewer problems in the Library Loading Report. You could also try these file converters:
ArchiCAD File converters
if that fails.
David
Thanks for your help I tried both ways and it didn't work.
Thanks again
