Opening elevation in plan view AC11
In plan view i highlight the elevation marker and associated line. Then i right click to open the elevation and nothing happens! I am thinking this is a problem because i have imported some AC10 template (through the attribute manager) stuff or is it something else?
2 Replies 2
Link
What OS are you using ArchiCAD on?
It may be that your elevation window is minimized. Look at the bottom left of your ArchiCAD screen and see if there's a minimized window down there. Otherwise the window may just be hiding somewhere else.
Have you tried opening the window by double clicking the view/viewpoint in the Navigator or Organizer?
Also, take a look under your Window menu. If the elevation is listed there, that means it is open - somewhere.
Link.
You say nothing happens? Not even the context menu?
Are you on Mac or PC?
If Mac then perhaps the right click is not enabled.
