Opening elevation in plan view AC11
In plan view i highlight the elevation marker and associated line. Then i right click to open the elevation and nothing happens! I am thinking this is a problem because i have imported some AC10 template (through the attribute manager) stuff or is it something else?
Link
What OS are you using ArchiCAD on?
It may be that your elevation window is minimized. Look at the bottom left of your ArchiCAD screen and see if there's a minimized window down there. Otherwise the window may just be hiding somewhere else.
Have you tried opening the window by double clicking the view/viewpoint in the Navigator or Organizer?
Also, take a look under your Window menu. If the elevation is listed there, that means it is open - somewhere.
Link.
You say nothing happens? Not even the context menu?
Are you on Mac or PC?
If Mac then perhaps the right click is not enabled.
