Organiser palette
jarkwiat
Hi !
When I open Organiser palette, AC asks "save changes ?" even if I change nothing in project - is it normal ?
Forgive my english
ArchiCAD 29 POL FULL iMac 20,1 Intel Core i5 3,1 GHz 24GB RAM AMD Radeon Pro 5300 4 GB
Your English is fine!
I see similar behavior. I normally have Organizer open. If I then open Navigator, I am prompted to save changes on exit. I have a vague memory of reporting this behavior during beta 10.
This seems to be a minor bug to me. The open/closed state of palettes and what they display is part of the Work Environment - even the dynamically adjusted one - and is saved in the ArchiCAD preferences, not in the project file. Only if a view is defined, redefined, drawing placed, etc etc should the prompt happen.
jarkwiat
Thanks !
It means my AC is "fine" ...
Regards... Jarek
