PROJECT ORIGIN
I started a new file and some how everything is being referenced to the PROJECT ORIGIN and its annoying me having to reset the USER ORIGIN constantly. Any idea where can I configure the file not to do that?
3 Replies 3
If you are using the Coordinate Box for numeric input, then you can switch it to Relative coordinates, not absolute coordinates.
If you are using the Tracker, you should have the "Relative Coordinates in Tracker" option enabled.
< köszönöm
Szívesen (You're welcome)
