Palettes offscreen / disappearing
jbArch
Some of my palettes are disappearing when I use my laptop, most likely offscreen.
I go between a normal monitor and my laptop display, so I have two different work environment profiles setup: one for the 19" LCD, another for the 15.4" laptop. So I thought I had this under control (i.e. I understand why the palettes fly offscreen when I switch to the small monitor).
But the quicklayers palette is still causing me some grief. It never stays visible when I restart archicad, no matter what display I use. So it also won't "stick" with my work environment profiles.
How can I get the quicklayers palette to show up again in my current profile? And how can I get it to be there again when I restart archicad?
TIA & Cheers,
JB
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
5 REPLIES 5
__archiben
unfortunately you can't. the quicklayers palette has never been a part of the work environment palette schemes.
for that reason i have the quicklayers commands in my toolbar - then i actually have control over their appearance . . .
it's a shocker that three years after the introduction of the 'work environment' there are still palettes and main dialogues that still don't conform.
~/archiben
b e n _ f r o s t
Aussie John
You need to make a separate pallette scheme for the laptop as indeed they are off the screen due to the different resolutions of your main computer and the laptop.
Cheers John
[/size]
jbArch
Thanks Ben... that solves the problem for me. I didn't know I could customize the toolbar, so until now I'd been hanging onto my old ways and using the vertical toolbox. If I can get more customization out of the toolbar, then I'll give it a shot.
JB
__archiben
go crazy >
b e n _ f r o s t
jbArch
Thanks Ben. Looking forward to playing around with that one... After I finish this deadline.
JB
