Panther and W2000 server
A clean install will not allow to open files in W200 server. Many files (the old MAC files with no extension) will appear as "unix executable files" but will be impossible to open them even with adding the correct extension. If you encounter this situation reinstall Panther on top pd any OSX.
1 REPLY 1
MS addressed this problem in the latest patch, so it appears one could clean install Panther on a reinitialized HD and will be able to see all files on a W2000 server.
I did not tried this
