Param-o missing fill from existing (referenced) objects.
Florian99
hi all,
1. is an existing object,
2. in Param-o it is imported (like the two others)
I can change the fill to whatever I want in the original objects - Param-o shows always just lines, but nor fills.
How can I get my fills back?
Please, let there be a solution!! šŸ˜‰
KR, Florian
ā€ƒ
AC25, BIMCloud, Windows
As far as I know, the current implementation of Param-O does not include components to control the 2D representation of the generated object, I think this is the reason why your Fills are "lost".
Hopefully, future iterations will be more capable in this area as well.
5 REPLIES 5
Hi Laszlo,
Thanks for information; that is really unfortunate.
Param-o would have the potential to solve so many custom object related problems.
I hope too! šŸ™‚
KR, Florian
In what way would it be possible to create its own Param-o nodes?
Could you clarify this question?
What do you mean by "create its own Param-O Nodes"? You can not create your own Param-O Nodes, you have to work with the Nodes available, so new Nodes will be available when Graphisoft continues to develop Param-O.
Yes, the question was about the possibility to create own Param-o nodes.
Thanks for answer.
Looking forward to see the next iteration of that tool!
Thanks!
