Parameters Transfer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-07-01
02:10 PM
2023-05-23
04:48 PM
Rubia Torres
pd:sorry for my english!!!..i speak spanish...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 02:30 PM
The eye-dropper is activated by clicking the icon in the toolbar or with a keyboard shortcut (PC: holding down the ALT key; Mac: holding down the Option key).
The Syringe injects (PC: CTRL + ALT or MAC: CMD + OPT) those parameters into the target object.
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 02:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 02:47 PM
ArchiCAD Service
Mac, Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 02:49 PM
Srinivas wrote:no problem!!!!....
Apologize I mis understood your question.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 04:35 PM
I think that will do it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 05:13 PM
lec1212 wrote:it didnt work..
I believe if you pick up the the parameters from source window, then highlight the window you want to transfer to, go to dialog box inject into it before doing anything else.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 05:59 PM
Strangely it will keep all the common parameters settings (a, b, but many common parameters like pen type…) in the selected window, and replace this type of window by the type you are targeting. It does not work correctly if the two objects belong to very different libraries (ex AC v7 and AC v13). The more different are the libraries the more weird is the result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-01 07:35 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-02 03:49 AM
Having said that it is not impossible to do but only for transfering (or not transfering) parameters between different object in the objects settings dialogue box.
You cannot use this to transfer parameters on plan between objects.
You will have to edit and save your library parts.
Open the door (or any other part) and in the parameter list select the parameter you do not want to be altered and press the "U" button (I forget its proper name).
Save your object.
Now select the object you want the parameters of and open the object settings dialogue.
Find the object you want to stransfer to and CTRL-ALT click (inject) - don't just select it.
All parameters that are similar will transfer except those that you set not to.
I stress again this does not work in anything except the object settings dialogue and therefore does not work for different instances of the same object.
So not really the solution you are looking for but one worth knowing.
