ā2010-07-01
02:10 PM
ā2023-05-23
04:48 PM
Rubia Torres
ā2010-07-02 02:37 PM
Barry wrote:
It is not possible to pick and choose the parameters you would like to transfer - that would be nice though.
Having said that it is not impossible to do but only for transfering (or not transfering) parameters between different object in the objects settings dialogue box.
You cannot use this to transfer parameters on plan between objects.
You will have to edit and save your library parts.
Open the door (or any other part) and in the parameter list select the parameter you do not want to be altered and press the "U" button (I forget its proper name).
Save your object.
Now select the object you want the parameters of and open the object settings dialogue.
Find the object you want to stransfer to and CTRL-ALT click (inject) - don't just select it.
All parameters that are similar will transfer except those that you set not to.
I stress again this does not work in anything except the object settings dialogue and therefore does not work for different instances of the same object.
So not really the solution you are looking for but one worth knowing.
ā2010-07-02 03:13 PM
Barry wrote:Actually there are some some choices of parameters that can be made, just not the sizes of windows/doors. Check the Favorites Preferences for what choices are available.
ā2010-07-04 10:38 PM
Erika wrote:Similarly, pick up the properties from an existing window, change the dimensions in the tools' settings, then inject into existing or place a new window.
If you save a favorite of the W/D you like, double click on this favorite to activate it. In the settings box, change the sizes as you want and then inject the parameters.
ā2010-07-06 02:59 AM
ā2017-03-26 12:25 PM
ā2017-08-28 05:13 PM
vasil4y92 wrote:Thanks a lot! It really does work! Just saved me a ton of extra time.
Hello, i found the solution. It works on Archicad 20!
Workflow: To transfer parameters between objects of the same type, do the following:
Go In the object's Settings dialog box, make parameter modifications as needed, then place the object.
Use the Parameter Pickup shortcut (Hold <ALT>+click) to pick up the parameters of the placed object
Open the Settings dialog box.
Use the Parameter Transfer shortcut (Hold <CTRL>+<ALT>)
Move the cursor to the next object to be placed, until the cursor changes to the syringe (this may take a small amount of movement to find the syringe)
Click on the object to transfer the parameters. All transferable parameters of the originally modified object will be transferred to the newly selected object.
Place the object using the changed parameters.
ā2017-08-29 02:57 AM
marmoss wrote:It is not quite as easy as this.vasil4y92 wrote:Thanks a lot! It really does work! Just saved me a ton of extra time.
