Parametric Selection
is there any way to select set of elements sharing some properties, like color, layer, composite type for walls, base line offset .......?
I constantly need to perform some operations on, or change properties of set of object, but thos sets change so grouping them dose not do any good.
Cris
2 Replies 2
Hello Cris
You may use the "Find and Select" fonction which allow very powerful combinations to select just a kind of element.
thanks
thats what I need
