Parametric Selection
is there any way to select set of elements sharing some properties, like color, layer, composite type for walls, base line offset .......?
I constantly need to perform some operations on, or change properties of set of object, but thos sets change so grouping them dose not do any good.
Cris
Hello Cris
You may use the "Find and Select" fonction which allow very powerful combinations to select just a kind of element.
thanks
thats what I need
