Pasted 3d Vect. hatch vanishes when moved.
Currently working on saving some 3d views, and I want to be able to paste them to a 2d window to clean them up(no my model is not perfect, and this is faster for the moment).
So I have used a dotted pattern to represent stucco, and in perspective it looks great. I also have a nice long curvy pattern to look like rough-hewn wood (can you believe I work in NYC?) Here is the problem: I copy the view from 3d, and paste it on the floor plan (or section or detail window) and the hatch is there. A-OK. Then I want to move my drawing to make room for my next view, and my stucco vanishes, but note my curvy wood pattern remains. If I don't move it, no problem, I can clean my drawing, and get the final result I want. But I don't want to have a separate window for each drawing. (10 views = 10 extra stories, section or details. 1 should do).
My current theory is that the stucco (dotted pattern) creates lines that are really, really short. When I try to move them, Archicad thinks there is nothing there and so it wants to help clean up my mess...drawing.
What's the solution?
-Nathan Brauer
2 REPLIES 2
Aussie John
I am not sure what you problem is but copy and pasting vectorial fills in 3d will result in convertion to lines. Not a very desirable arrangment as it will increase file size and complexitiy of the redraw. Editing could become a nightmare. Maybe your converted stucco pattern is taxing your video card too much.
BTW I put all my section views in separate windows. One thing I really hate is getting a drawing from someone who has put all their sections or elevations into one window. Future editing and changes ar a pain and become untrustworthy particulary inregard to real levels or dimensions.
Also as you hve noted the window can get overloaded with too much "line" information.
When I first started with Archicad (over 12 years ago) I had noone to help me. I still vividly remember creating an office reflected ceiling plan where I used lines to create everything including the light fittings ( which of course should of be objects). The screen redraw times were ridiculously long.
Cheers John
[/size]
Djordje
Don't.
Clean your model up, and make yourself do it properly. Doing that takes LESS time than tarting up the copied lines; line overload notwithstanding.
I love the sound of Publisher chugging away ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
