Pen shapes change?
is there any way to change the pens line shape?
I want them to be square-like, like here below:
10 Replies 10
Erich
Sorry, this is not possible.
However, depending on why you were hoping to change pen shape, there may be other options. What was it you wanted to accomplish that requires the "square" pen?
For instance, you may want a sharp square edge for a boarder on a title block. For something like that consider using a fill with the center cut out. This will result in a clean square edged corner.
Lastly, welcome to the forum. I suggest that you fill out a signature (Click "Profile" at the top of the page) and add information about which version on ArchiCAD you are using (see mine below for an example), and some basic information about the machine you are using. This information is often essential to answering questions as the answers can often vary depending on such factors.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Take a look:
When I make maps etc, it always looks crayon-like:)
The fills can be done, but lines - its too hard:(
This is one of many long-standing wishes for control over line display.
See this 'wish' thread and vote:
http://archicad-talk.graphisoft.com/viewtopic.php?t=941
...although your example of a true heavy dashed line might be added to that wish to give a good graphic example of this issue. You'll notice that the wish thread started more than 5 years ago...
OK, I see.
Well I hope they will add it soon.
I was pretty sure its not possible, yet its always better to ask(and find that some people have wished for this for 5 years:D)
Can you add my drawing there? Im not sure how and where to put this:)
There is a workaround for this but it is not great. Lines are don't miter at the ends and the dash strictly follows its module so it may be void at one end. Polylines clean up the corners but taper them in a strange way.
Kind of a drag to be so close but no cigar on such a long standing wish.
If you want it despite the limitations here is an aat file...
There are also tricks with walls and fills but they suffer from their own set of problems.
(These use a striped fill with no outlines.)
Eduardo Rolon
Another option is to export the pdf and edit the line in Illustrator, there you can specify the square option. Before exporting the pdf make sure that the line has an unique color, linetype or thickness so that you can use the "select same…" menu command and then apply the change.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I recall Dwight offering a suggestion for square lines a while back (but a quick search hasn't found it). Basically it was a linetype created with multiple dashed lines offset from each other by the relevant pen thickness. I can't remember the intracacies but have a go, or Dwight may be able to point us to his original post.
