Pen weight problem
Hello!
I have a problem with the pen weights in scale 1:10 The lines are too thick. I tried to correct the thickness in attributes -> pens & colors. I reduced the pen weight to 0.01 but nothing change in the layouts.
After you modify the pen set thicknesses, SAVE as a New Pen Set. Then apply that pen set to the selected drawing on the Layout and all will be ok.
Thank you so much! I'm gonna try.
Vitruvius
I've done the following:
Pen Set 1 - Plans @ 1:50 say
Pen Set 2 - Details @ 1:10 say
For example, you can assign Pen 1 to exterior walls, etc. and then call up Pen Set 1 for plans and Pen Set 2 for details. Pen 1 then has separate, but appropriate weights for each scale.
Cheers
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
