Perspective that looks more axonometric
alexandarland
Hello everyone.
I am looking for particular setting of a single camera in regular perspective view from above (please see image Perspective). What I would like to do is to make it look more "axonometric" , not quite as the other attached image, but something in between. I tried all settings I knew, but obviously without success.
Do you know what should I do?
I am using AC21.
Guru
Reduce your View Cone in 3D? Would mean that you will have to zoom out further, but it will reduce the perspective. Though you cannot truly look straight down in AC... That 10mm horizontal distance between camera and focal point... Close, but not quite...
Ling.
Guru
Ling.
alexandarland
THANK YOU!
This is it
