Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Placing a Beam Out of Plane
How do you place a beam on a 45 degree angle against a vertical column to form a bracing element and then another at 135 degrees to intersect and then another beam parallel to the base surface
adzik
When you open the Beam settings dialog (Cmd+T) then there right next to the Home Story drop down menu you can select if your beam is horizontal or at an angle. Next to it you can enter the needed angle as well.
Running ArchiCAD 23 INT.
Srinivas
Peter,
Is this what you wanted to model?
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Ralph Wessel
Mentor
Or this...?
Ralph Wessel BArch
Software Engineer Speckle Systems
