Plan cut height
Is there any way to set the plan view's cut height so it doesn't show anything above a certain point or maybe even a detail drawing with vertical limits? I am using ArchiCAD 8. Thanks in advance.
6 Replies 6
Vitruvius
You need to use layers and view sets to do this. I put all my reflected ceiling stuff on separate layers and create a layer set & view set which displays this.
Cheers
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Archicad does not work by generating a 'horizontal section' for plan views. You will have to manipulate this with layers if at all possible..
Thomas Holm
Yes of course you can do a true horizontal cut, John! There's the 3D cutting planes /Cutaway command, (Image menu) that lets you create a true horizontal cut through a model in the 3D window. You can then save a parallell top view and get a plan view.
However, the Floor plan window is a symbolic representation of the model (just like a construction document plan usually is). There, you cannot define a cut height, instead items on the current floor display according to their respective settings, even if they are placed on top of each other.
For certain presentations, it can be useful to combine these - to place a saved "3D cut" view on a Floor plan view. For example, it can be a way to enhance a floor plan with shadows. However, this combination of the saved views must be done in a layout program, such as Plotmaker.
I miss this type of feature....it would be really cool to have a toggle like in Triforma where you can set the height and then view either the reflected ceiling view or the plan view....maybe in AC10
Thomas Holm
Well, as I said you can do what you want in the 3D view with a little bit of work. You can place cut planes however you like, and then view the remaining shebang from top, bottom or anyway with all perspective options available in the 3D window. However, if you want to add lines, text and other symbolic or 2D items, you have to save the 3D view and import it into something else.
A more efficient way to get your message through is probably to work with layer combinations and display options in the plan window, to get representations of cut lines and reflected ceilings etc, and then save the views accordingly. It's less work to have them updated this way.
I agree that Microstation's view flexibility is a wish - long standing one as I see it. In MS, (and Triforma) you can define any view as you like, and have several (up to 8, is it still?) open, real-time updated and active simultaneously.
In Archicad you have three kinds:
1. The symbolic working plan window. This is unique to Archicad, very efficient when working, always real-time updated but you can only have one open at a time, showing one floor with optionally one other "ghosted" (like tracing paper). I don't want them to take this window away. But it could of course improve.
2. The 3D window. Very flexible, but shows only "real" items, no 2D, lines, text or symbols, and only one open at a time. Has to be generated, which takes processor time.
I would like to have a foreground and a background 2D layer added, where you could place symbolic items.
3. The section window. Has to be generated/updated, but you can have as many different open as you want. A mix of "real" items and 2D symbols, it can show what you want, and you can draw freely in it. But as a reflection of the model, it can just have vertical cut planes, and a projection perpendicular to the cut plane.
(Edited: I forgot the detail window - well i don't think it matters much here)
OK, my wishes:
You should be able to open (and save) a number of different views of any kind simultaneously. All open and visible views should update in real time.
When you open a new one, you should be able to define its kind, as any of the above, or even a rendered image.
You should be able to rotate views freely, sections also in 3D, and also their cut planes, both top and bottom.
You should be able to add graphic and symbolic items to any view, and decide whether they should show in renderings or not.
Since all OSs are multithreaded these days, every view (set to auto-update) in a project should have its own background update thread, that triggers at once when you change something in the model, and works in the background. This way you would almost always find the views completely updated already when you open them.
You sure triggered me!
Now back to work!
Thanks everyone. I had a close deadline so I ended up exporting the 3d model as a 3ds and using 3d studio max to slice off the top and then exporting the top down view to a DWG and importing back into AC
