‎2005-03-14 07:27 PM
‎2005-03-15 04:20 PM
‎2005-03-15 06:19 PM
‎2005-03-15 07:35 PM
johnsoja48 wrote:I think you are out of luck. The "window" size will adjust to the drawing if you use fit to drawing, but the window location will change (I would guess relative to the global origin).
Thanks Mike for the help. That is kind of what I was after, but is there a way to lock frame to the layout and fit the drawing to the frame?
