PlotMaker 3.1 viewport problem
After mirroring a project in ArchiCAD, the views in plotmaker don't automatically zoom to best fit. Is there away to set up plotmaker so that it automatically zoom all views to best fit
If I interpret what you are asking, while in plotmaker, select all of the imported views, go to drawing settings, and under the "frame and output color" section select "fit frame to drawing".
Thanks Mike for the help. That is kind of what I was after, but is there a way to lock frame to the layout and fit the drawing to the frame?
I think you are out of luck. The "window" size will adjust to the drawing if you use fit to drawing, but the window location will change (I would guess relative to the global origin).
